  2. Allegro X Capture CIS
  3. Missing Advanced Annotation button
  • State Suggested Answer
  • Answers 1
  • Subscribers 51
  • Views 12143
Fredda
Fredda over 4 years ago
By some reason the Advanced Annotation button is missing in the Annotate dialog box. How do I get it back??
Right picture is my Capture installation. Left picture from another Capture installation.
Version is OrCAD Capture CIS 17.4-2019 S024 (3998392) [12/6/2021].
/F
  • Akshay khosla
    Akshay khosla over 4 years ago in reply to Fredda +1 suggested
    Yes Fredda, once we launch Capture it will create a new capture.ini file after renaming. Is the project, pspice simulation enabled? Advance annotation option does not comes in pspice simulation enabled…
  • Akshay khosla
    0 Akshay khosla over 4 years ago
    Try renaming Capture.ini present at location %HOME%\cdssetup\OrCAD_Capture\17.4.0 after closing the capture.
  • Fredda
    0 Fredda over 4 years ago in reply to Akshay khosla
    I guess the purpose with renaming the ini-file is to force Capture to create a new one? Anyhow, that didn't work.
  • Akshay khosla
    0 Akshay khosla over 4 years ago in reply to Fredda
    Advance annotation option does not comes in pspice simulation enabled designs. Please check on other designs without pspice enabled flow.
  • Fredda
    Yes, pspice simulation is enabled, but nothing I'm using so it can be turned off. If I only can find out where!? Thanks.
  • Fredda
    0 Fredda over 4 years ago in reply to Fredda
    I ended up editing the opj-file and changed to:
    (ProjectType "PCB")
    Now the Advanced Annotation button is back! Many thanks! This was an insidious trap...
