  2. Allegro X Capture CIS
  3. BOM, NETLIST GENERATION USING COMMAND PROMPT
  • Replies 12
  • Subscribers 51
  • Views 16147
Shanmugi
Shanmugi over 4 years ago
I am working on project where I need to generate Netlist and BOM from command prompt without opening ORCAD.
As I am new to ORCAD, it would be heplful if somebody help me on the same.
I have read previous blogs and post regarding this, but it is unhelpful for me.
Kindly tell me some better and efficient way to do this.
Thanks for helping me in advance!
  • jc teyssier
    jc teyssier over 4 years ago in reply to Shanmugi
    I always run this command in the dsn file location.
    Let say tour dsn ffle is my_scheamtic.dsn
    Let say you have an -my_netlist directory and want the netlist written at this location.
    Let say you have a config file  D:\myconfig\allegro.cfg
    Let say you wish to retain the 3 last version of netlist
    Let say you use long names in schematic. The amximum caracter length is 255
    Open a cmd window (a dos terminal) and go into schematic location.
    the command to type in dos command window to extract netlist will be
    pstswp.exe -pst -d my_scheamtic.dsn -n my_netlist -c D:\myconfig\allegro.cfg -v 3 -l 255
  • Shanmugi
    Shanmugi over 4 years ago in reply to jc teyssier
    Thanks for your reply and it is very helpful.
  • Shanmugi
    Shanmugi over 4 years ago in reply to Shanmugi
     One more query is it possible to generate netlist file of format orWirelist64.dll in command prompt?
  • jc teyssier
    I have a try in capture: seems it does not run an external command, so no, you have to open capture to extract such netlist.
  • Shanmugi
    Do you know how to generate orWirelist64.dll using TCL scripts by any chance?
    I found this link for generating BOM using TCL scripts.
    https://community.cadence.com/cadence_technology_forums/pcb-design/f/pcb-design/25029/how-to-generate-a-bom-from-orcad-using-a-tcl-script
