  2. Allegro X Capture CIS
  3. BOM, NETLIST GENERATION USING COMMAND PROMPT
  • Replies 12
  • Subscribers 51
  • Views 16146
Shanmugi
Shanmugi over 4 years ago
I am working on project where I need to generate Netlist and BOM from command prompt without opening ORCAD.
As I am new to ORCAD, it would be heplful if somebody help me on the same.
I have read previous blogs and post regarding this, but it is unhelpful for me.
Kindly tell me some better and efficient way to do this.
Thanks for helping me in advance!
  • jc teyssier
    jc teyssier over 4 years ago
    open schematic in orcad capture and run the netlister: you will see tyhe command running in console.
    This is what i have done.
    Now i can run this command from command window (dos cmd): (replace <xxxx> by your values)
    pstswp.exe -pst -d <your_design.DSN> -n <oath of output netlist directory> -c < your allegro.cfg file> -v <number of version file to retain> -l <maximum length of device/net/pin name>
    I guess you need to have a orcad capture licence available in order to run this communard.
    The bom extraction seem to not show the command running behind in console.
  • Shanmugi
    Shanmugi over 4 years ago in reply to jc teyssier
    Thanks for your response. is the above command only for netlist and not for BOM?
  • jc teyssier
    jc teyssier over 4 years ago in reply to Shanmugi
    Only for netlist:. I do not know how to extract bom without openeng capture
  • Shanmugi
    When I run the netlister, i successfully got like the format u mentioned in your reply like, pstswp.exe -pst -d <your_design.DSN> -n <oath of output netlist directory> -c < your allegro.cfg file> -v <number of version file to retain> -l <maximum length of device/net/pin name> which i mentioned in the above image.
    But i dont understand what is mean by  (dos cmd): (replace <xxxx> by your values).
    Can you explain briefly?
  • Shanmugi
    Shanmugi over 4 years ago in reply to Shanmugi
    Or can you tell how i should run this command in my windows command prompt?
