  2. Allegro X Capture CIS
  3. Access ORCAD command window using windows command promp...
  • State Verified Answer
  • Subscribers 51
  • Views 10639
Access ORCAD command window using windows command prompt
Shanmugi
Shanmugi over 4 years ago
I need to access the ORCAD's command window without opening ORCAD from windows command prompt (usually run the TCL scripts in orcad command window), but trying to run the tcl scripts in windows command prompt.
Is there a way to access it externally.
Kindly help me on the same.
Thanks for your help in advance!
  • CadAP
    CadAP over 2 years ago in reply to AB_1717543042707 +1 verified
    Hi AB_1717543042707 , Please go to the loaction C:\Cadence\SPB_22.1\tools\capture\tclscripts (if you have installed SPB_22.1) and open the pdf file OrCAD_Capture_TclTk_Extensions.pdf On page no-44…
  • AB_1717543042707
    0 AB_1717543042707 over 2 years ago
    Did you ever come up with a solution? I am facing a similar problem but have not come up with a solution for this. Any advice would be appreciated.
  • CadAP
    +1 CadAP over 2 years ago in reply to AB_1717543042707
    Hi AB_1717543042707,
    On page no-44("4.2 Script and Usage") you will find the information about the script run in standalone TCL Shell.
    Hope this helps!
