  2. Allegro X Capture CIS
  3. Packaging made easy - Advanced Annotation
  • Subscribers 49
  • Views 1371
DesignTech
DesignTech over 4 years ago
Capture packages components on the fly. When Auto Reference is enabled, any new part in the design gets a unique reference designator automatically. You don’t really need to manually annotate the design.
Still, if you want some custom refdes ranges, Capture has you covered. Use the Advanced Annotation feature to assign references on selective pages, blocks, and even based on property values.
You can open the Advanced Annotation UI from the Annotate dialog.
Regards
Team DesignTech
Cadence Design Systems
