  2. Allegro X Capture CIS
  3. Capture CIS 17.4 Crashes on the latest Windows 11 Dev 25126...
  • State Suggested Answer
  • Answers 1
  • Subscribers 54
  • Views 17293
Capture CIS 17.4 Crashes on the latest Windows 11 Dev 25126.1
kazutoiris
kazutoiris over 4 years ago
I update to Windows 11 Dev 25126.1 in recent days. After I updated, I've noticed that Capture CIS 17.4 can't be open. It'll crash when launched.
I've tried to re-install, update to the newest version. Neither of them work.
Fortunately, it generated the memory dump when crashed. I open this file in WinDBG, it shows that `cdn_og1210as64.dll` causes the bug. Stack overflow happened in function `XMLSerialize`.
The dump file was uploaded to WeTransfer(https://we.tl/t-sWfHyAcvQF).
Microsoft (R) Windows Debugger Version 10.0.25111.1000 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [Capture.exe.22648.dmp]
User Mini Dump File: Only registers, stack and portions of memory are available
************* Path validation summary **************
Response Time (ms) Location
Deferred srv*
Deferred cache*symbol
Deferred srv*msdl.microsoft.com/.../symbols
Symbol search path is: srv*;cache*symbol;srv*msdl.microsoft.com/.../symbols
Executable search path is:
Windows 10 Version 25126 MP (4 procs) Free x64
Product: WinNt, suite: SingleUserTS
Edition build lab: 25126.1000.amd64fre.rs_prerelease.220521-1727
Machine Name:
Debug session time: Sun May 29 01:12:59.000 2022 (UTC + 8:00)
System Uptime: not available
Process Uptime: 0 days 0:00:47.000
Loading unloaded module list
This dump file has an exception of interest stored in it.
The stored exception information can be accessed via .ecxr.
(5878.34f0): Security check failure or stack buffer overrun - code c0000409 (first/second chance not available)
Subcode: 0x2 FAST_FAIL_STACK_COOKIE_CHECK_FAILURE
For analysis of this file, run !analyze -v
cdn_og1210as64!CStringXMLCompatibleFTR::XMLSerialize+0x20b4:
00007ffc`dafab5e4 cd29 int 29h
0:000> !analyze -v
* Exception Analysis *
KEY_VALUES_STRING: 1
Key : Analysis.CPU.mSec
Value: 2249
Key : Analysis.DebugAnalysisManager
Value: Create
Key : Analysis.Elapsed.mSec
Value: 222408
Key : Analysis.Init.CPU.mSec
Value: 1765
Key : Analysis.Init.Elapsed.mSec
Value: 20077
Key : Analysis.Memory.CommitPeak.Mb
Value: 143
Key : FailFast.Name
Value: STACK_COOKIE_CHECK_FAILURE
Key : FailFast.Type
Value: 2
Key : Timeline.Process.Start.DeltaSec
Value: 47
Key : WER.OS.Branch
Value: rs_prerelease
Key : WER.OS.Timestamp
Value: 2022-05-21T17:27:00Z
Key : WER.OS.Version
Value: 10.0.25126.1000
Key : WER.Process.Version
Value: 17.4.0.0
FILE_IN_CAB: Capture.exe.22648.dmp
NTGLOBALFLAG: 0
APPLICATION_VERIFIER_FLAGS: 0
CONTEXT: (.ecxr)
rax=0000000000000001 rbx=000000c1babfc11c rcx=0000000000000002
rdx=000000c1babfc0d9 rsi=000000c1babfc080 rdi=000000000000003d
rip=00007ffcdafab5e4 rsp=000000c1babfbf30 rbp=000000c1babfc09c
r8=000000000000003d r9=8101010101010100 r10=810100fefef900f8
r11=000000c1babfcdc0 r12=000000c1babfc190 r13=000000c1babfcdc0
r14=000000c1babfc5b0 r15=0000000000000002
iopl=0 nv up ei pl nz na pe nc
cs=0033 ss=002b ds=002b es=002b fs=0053 gs=002b efl=00000202
Resetting default scope
EXCEPTION_RECORD: (.exr -1)
ExceptionAddress: 00007ffcdafab5e4 (cdn_og1210as64!CStringXMLCompatibleFTR::XMLSerialize+0x00000000000020b4)
ExceptionCode: c0000409 (Security check failure or stack buffer overrun)
ExceptionFlags: 00000001
NumberParameters: 1
Parameter[0]: 0000000000000002
PROCESS_NAME: Capture.exe
ERROR_CODE: (NTSTATUS) 0xc0000409 - <Unable to get error code text>
EXCEPTION_CODE_STR: c0000409
EXCEPTION_PARAMETER1: 0000000000000002
FAULTING_THREAD: 000034f0
STACK_TEXT:
000000c1`babfbf30 00007ffc`daf81812 : 0000f580`d12b0370 000000c1`babfc09c 000000c1`babfc080 000000c1`babfc11c : cdn_og1210as64!CStringXMLCompatibleFTR::XMLSerialize+0x20b4
000000c1`babfbf70 00007ffd`83d3ac3e : 00000230`9839e32c 00000230`9839e32c 00000000`00007000 00000000`00000000 : cdn_og1210as64!CGXFont::WriteProfile+0x2b6
000000c1`babfc050 00007ffd`83d39941 : 00000000`00000000 00000230`985f13e0 000000c1`babfc4c0 000000c1`babf0000 : gdi32full!iAnsiCallback+0xb0
000000c1`babfc3b0 00007ffd`83d51841 : 00000000`3901120b 00000000`00000000 00007ffc`daf8171c 00007ffc`daf8171c : gdi32full!EnumFontsInternalW+0x76d9
000000c1`babfc430 00007ffd`83d3a782 : 000000c1`babfc5b0 00000000`3901120b 000000c1`babfc570 00000000`004a0048 : gdi32full!EnumFontsInternalA+0xc5
000000c1`babfc490 00007ffd`8553d9f0 : 00000230`997b06e0 00007ffd`83d4d8e1 00000000`00000000 00007ffd`83e7c594 : gdi32full!EnumFontFamiliesExA+0x42
000000c1`babfc4d0 00007ffc`daf7fcf1 : 00000000`00000000 000000c1`babfc620 00000000`00000001 00000804`00000001 : gdi32!EnumFontFamiliesExAStub+0x50
000000c1`babfc520 00007ffc`dae57ed3 : 00000230`997b03f0 00000230`997b0070 00000000`00000001 00007ffc`db0dbae0 : cdn_og1210as64!GX_FONT_STATE::GX_FONT_STATE+0x119
000000c1`babfce20 00007ffc`dae58745 : 00000230`997b0070 00000230`997b06a8 000000c1`babfcee0 00000000`00000000 : cdn_og1210as64!CGXLangDll::CGXLangDll+0x87
000000c1`babfce60 00007ffc`dae586d3 : 00000000`00000001 00007ffc`d961d7a5 ffffffff`fffffffe 00000230`997b0070 : cdn_og1210as64!GXGetResourceHandle+0xb9
000000c1`babfceb0 00007ffc`daea0747 : 00000000`00000000 00000230`9a782f70 00000000`00000000 00000000`00000e00 : cdn_og1210as64!GXGetResourceHandle+0x47
000000c1`babfcee0 00007ff6`e5b0fcbc : 00007ff6`e65f8ca0 00007ff6`e5660000 00007ff6`e5660000 00000000`00000001 : cdn_og1210as64!GXInit+0x2f
000000c1`babfcf20 00007ffc`d9841744 : 00000000`00003a43 00000230`00000000 00000230`00000001 00000230`99328be8 : Capture!Capture_Init+0x10786c
000000c1`babff900 00007ff6`e5d9daf3 : 00000000`00000001 00000000`00000000 00000000`00000000 00000000`00000000 : mfc140!AfxWinMain+0x84
000000c1`babff940 00007ffd`8440244d : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : Capture!COrSrcFrameWnd::CanShowOnTaskBarTabs+0x19dd63
000000c1`babff980 00007ffd`8642adf8 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : kernel32!BaseThreadInitThunk+0x1d
000000c1`babff9b0 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : ntdll!RtlUserThreadStart+0x28
STACK_COMMAND: ~0s ; .cxr ; kb
SYMBOL_NAME: cdn_og1210as64+20b4
MODULE_NAME: cdn_og1210as64
IMAGE_NAME: cdn_og1210as64.dll
FAILURE_BUCKET_ID: FAIL_FAST_STACK_BUFFER_OVERRUN_STACK_COOKIE_CHECK_FAILURE_MISSING_GSFRAME_c0000409_cdn_og1210as64.dll!Unknown
OS_VERSION: 10.0.25126.1000
BUILDLAB_STR: rs_prerelease
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
IMAGE_VERSION: 12.1.0.0
FAILURE_ID_HASH: {328d5b57-589f-1537-edbc-60950f96d99f}
Followup: MachineOwner
0:000> lmvm cdn_og1210as64
Browse full module list
start end module name
00007ffc`dae50000 00007ffc`db10d000 cdn_og1210as64 (export symbols) cdn_og1210as64.dll
Loaded symbol image file: cdn_og1210as64.dll
Mapped memory image file: Cadence\SPB_17.4\tools\bin\cdn_og1210as64.dll
Image path: Cadence\SPB_17.4\tools\bin\cdn_og1210as64.dll
Image name: cdn_og1210as64.dll
Browse all global symbols functions data
Timestamp: Mon Aug 6 21:27:53 2018 (5B684CD9)
CheckSum: 002C0B70
ImageSize: 002BD000
File version: 12.1.0.0
Product version: 12.1.0.0
File flags: 0 (Mask 3F)
File OS: 40004 NT Win32
File type: 2.0 Dll
File date: 00000000.00000000
Translations: 0409.04e4
Information from resource tables:
CompanyName: Rogue Wave Software
ProductName: Objective Grid
InternalName: GXDLLR
OriginalFilename: GX"1210"R.DLL
ProductVersion: 12.1.0
FileVersion: 12.1.0
FileDescription: ObjGrid DLL Shared Library - Release Version
LegalCopyright: Copyright (c) 1997-2015 Rogue Wave Software, Inc. All Rights Reserved.
  • Board Burner
    Board Burner over 2 years ago in reply to kevcon +1 suggested
    I have a Windows 10 corporate laptop and just came across this also (5/7/2024). My install had put the SPB folder at C:\ and I think the install was for "All Users". After uninstalling and deleting this…
  • AyushD
    0 AyushD over 4 years ago
    Capture 17.4 is not yet officially supported on Win 11
  • Daniel Arvelund
    0 Daniel Arvelund over 4 years ago
    I just upgraded to Win 11 and now I have the same problem for OrCAD Capture 17.2 and OrCAD Capture 17.2 with CIS option. The program freezes while loading, just before showing the start screen.
    Any updates on this matter?
  • rg13
    0 rg13 over 4 years ago in reply to Daniel Arvelund
    Capture 17.2 is not supported on Windows 11.
  • kevcon
    0 kevcon over 2 years ago
    Has anyone else run across this issue and found a solution?
    I have a windows 10 laptop with 17.4 and I am getting the same error/problem.
  • Board Burner
    0 Board Burner over 2 years ago in reply to kevcon
    My install had put the SPB folder at C:\ and I think the install was for "All Users". After uninstalling and deleting this folder I reinstalled  Allegro using "Just Me" and not the "Everyone" on the machine.  This prevents others who remote into the machine from accidently altering any setup files.
    This time around, I also accepted the default location for the SPB of AppData/Roaming/Cadence
    After all this, the program launches with the Orcad Example design on the splash screen. Now the File >> Open command works, etc.
