  2. Allegro X Capture CIS
  3. ORCA- ERROR 1655
  • Subscribers 50
  • Views 2226
ORCA- ERROR 1655
soulmate58
soulmate58 over 4 years ago
can you pls. check and advise what is the reason to have this error log ? Thanks.
INI File Location:C:\SPB_DATA\cdssetup\OrCAD_CaptureViewer_Install/17.4.0/Capture.ini
Could not find S:\SAF85xx_V1_2\_COMMON_V1_2\STRX_IC_CUST\STRX_IC_CUST.DSN
ERROR(ORCAP-1387): Part IRISO_CONN (/IRISO_CONN at 9.35,3.30 on X-STRX-CAB-V4:04- TOP_LEVEL_MAIN) refers to missing schematic IRISO (in file S:\SAF85xx_V1_2\_COMMON_V1_2\IRISO\CAB_V4\IRISO_CONN_CAB_V4.DSN)
ERROR(ORCAP-1655): Referenced Schematic(s) Not Found
Incomplete design.
The implementation path of hierarchical block / part is incorrect.
Click on the part in the schematic page, and correct the specified Implementation path.
Note: If the referenced schematic is contained in the design, then it is not necessary to specify an Implementation Path, and the Implementation Path cell in the property spreadsheet should be empty.
See the session log for the hierarchical block / parts which can cause this problem.
