  2. Allegro X Capture CIS
  3. ERROR (ORCIS-6233) with MySQL Database
  • Subscribers 51
  • Views 8911
Huy Nguyen
Huy Nguyen over 4 years ago
I am getting the following error with MySQL version 8.  From old postings, others have been successful in resolving this issue with the ANSI ODBC driver.  I have tried 32/64-bit of MYSQL ODBC8.0 ANSI Driver without success.
Thanks in advance!
  • oldmouldy
    0 oldmouldy over 4 years ago
    This seems to be working fine in my environment but one difference is that all of the field types I have, apart from Price, are defined as TEXT, rather than a fixed length VARCHAR. I suspect that everything will work as expected once the VARCHAR field types are changed to TEXT.
