  2. Allegro X Capture CIS
  3. Add Libraries from Design Entry HDL to Capture CIS
  • Subscribers 53
  • Views 12585
pareshcdac
pareshcdac over 4 years ago
Hi everyone,
  I'm kind of new to the adence software. I have libraries for Allegro Deisgn Entry HDL. I want to be able to use those libraries in Design Entry CIS.
Is it possible? If so, how?
Any input would be helpfule
  • rg13
    rg13 over 4 years ago +1
    You'll have to export those DEHDL libraries to Orcad Capture libraries. For exporting DEHDL libs to Orcad Capture libs, you would need Library Authoring license. If you have it, you can use Project Manager…
  • RFinley
    RFinley over 4 years ago +1
    Can Allegro System Capture use your HDL libraries and CIS libraries directly?
  • rg13
    rg13 over 4 years ago in reply to RFinley +1
    Yes, System Capture has capability to use both DEHDL and Capture libraries. In System Capture, you also get option to choose 'Library Mode' while creating new project where you can choose to work on project…
  • rg13
    0 rg13 over 4 years ago
    You'll have to export those DEHDL libraries to Orcad Capture libraries. For exporting DEHDL libs to Orcad Capture libs, you would need Library Authoring license. If you have it, you can use Project Manager menu 'Tools > Library Tools > Export'.
  • RFinley
    0 RFinley over 4 years ago
  • rg13
    0 rg13 over 4 years ago in reply to RFinley
    Yes, System Capture has capability to use both DEHDL and Capture libraries. In System Capture, you also get option to choose 'Library Mode' while creating new project where you can choose to work on project using either Capture libs or DEHDL libs.
  • pareshcdac
    0 pareshcdac over 4 years ago in reply to rg13
    Okay, thank you. I'll try that
  • Schulz Jordan
    0 Schulz Jordan over 4 years ago in reply to rg13
    I believe it needs PCB Librarian license not just design authoring license.
