  2. Allegro X Capture CIS
  3. OrCAD Capture : pins locked on schematic symbol (blockCommandStart...
  • Subscribers 50
  • Views 8916
OrCAD Capture : pins locked on schematic symbol (blockCommandStart / blockCommandEnd.)
SolderMonkey
SolderMonkey over 4 years ago
I'm having problems editing a schematic symbol in a library. The component body is under NDA (it's a Broadcom part) so I can not share the .olb here.
It's a hetrogeneous part with 14 sections.
13 of the 14 are behaving fine. But one section, "J",  isn't. I can not drag the pins around to form a sensibly layed out schematic body.
If I open the command window & drag a pin on a working section, I see the following in the command window:
Capture> OrSymbolEditor::execute selectObjectsAtPoint 2.85 3.92 false false true
Capture> OrSymbolEditor::execute dragSelectedPinObject {{"Pins":[{"StartX":2.8,"StartY":3.7,"HotSpotX":3,"HotSpotY":3.7}]}}
Moving to the problem section I get different results:
Capture> OrSymbolEditor::execute selectObjectsAtPoint 2.83 3.27 false false true
Capture> OrSymbolEditor::execute blockCommandStart
Capture> OrSymbolEditor::execute dragSelectedObject -1.4 -2
Capture> OrSymbolEditor::execute blockCommandEnd
So OrCAD definitely thinks I shouldn't do what I actually do really need to do. Can anyone please help me re-educate it?
  • SolderMonkey
    0 SolderMonkey over 4 years ago
    I appear to have a workaround. I'd still like to know what went wrong if anyone knows, but I'll document the woraround here in case anyone else has the same issues.
    Workaround is as follows:
    • Copy pin data for offending pins from Edit Pins window to clipboard.
    • Delete offending pins.
    • Add pin array to give the same number of pins that you just deleted.
    • Paste data from clipboard into edit pins window.
    Here's the detailed version:
    Step 1.
    Open the component section (in my case "J" )and ensure nothing is selected.
    Step 2
    In the component property sheet, select "Edit Pins"
    Step 3
    In the Edit Pins window, set Section to "J" to only show the pins in the offending section.
    Step 4
    Copy all the pin info to the clipboard. In the Edit pins window, press CTRL-A (select all) then CTRL-C (copy to clipboard.)
    Now close the Edit pins window.
    Step 5
    Draw a selection box around all the pins that are giving trouble. Press delete and wave them goodbye!
    Step 6
    Place a pin array, I had 80 pins before I deleted them, I need to add 80 in an array...
    Starting name = DummyPin
    Starting Number = 1
    Number of pins = 80
    Step 7
    Make sure nothing is selected, and pick "Edit Pins" again from the Property Sheet. Set section to "J" to only show pins on the troublesome component section.
    Step 8
    Paste in the data from the clipboard, first press CTRL-A (select all) then CTRL-V (paste). Hit "OK" in the Edit pins window.
    The new pins should have taken the parameters from the old ones. But unlike the old ones, they can be dragged and re-arranged.
