  2. Allegro X Capture CIS
  3. Netlist Error: duplicate reference found but cant find a...
  • Subscribers 51
  • Views 11492
Netlist Error: duplicate reference found but cant find a part with this ref
domkap
domkap over 4 years ago
Hello everyone
I'm running into a strange issue with Capture cis 17.4. I'm trying to to export a netlist but i'm getting the error "Duplicate reference found R117". Now the thing is that my schematic has only around 90 resistors and i can't find it with the "find" function.
Has anyone else ran into this Situation or knows a fix for it?
Thank you for your help in advance
  • steve
    0 steve over 4 years ago
    Try the Edit - Browse - Parts command. Choose the preferred mode and OK. You'll now see a list based on refdes that should show you all the parts in the design.
  • domkap
    0 domkap over 4 years ago in reply to steve
    There isn't a R117 in that list as well
    EDIT: Found a "Fix".  For whatever reason there was a R117 in the PCB layout. I did the following steps not knowing what actually fixed it:
    1.Removed R117 from PCB
    2. Placed a R117 in schematic.
    3. synced pcb to schematic(worked)
    4. removed R117 from schematic and synced again...
