  2. Allegro X Capture CIS
  3. READONLY Issue with private LIBRARY1.OLD with Capture 17...
  • State Suggested Answer
  • Answers 1
  • Subscribers 52
  • Views 10996
READONLY Issue with private LIBRARY1.OLD with Capture 17.2-2016 SO83 only on first open of Project
CseaTec
CseaTec over 4 years ago
Someone had posted about this before in 2017, but the question got locked before anyone answered it. I am now having the same issue with the latest Capture 17.2. It would seem that whenever I launch Capture and open a previous project that uses my LIBRARY1.OLB that I made a while ago, I get prompted with an alert that asks if I want to open it readonly.  If I click No, the library is not always accessible from within the project hierarchy.  If I then close the project and reopen it, the prompt does not occur and everything is fine.  I can then close & open multiple projects without this prompt reoccurring. But if I totally close out Capture and restart it, the prompt reoccurs (one time again) when I re-open a project that uses this library.
Can anyone explain this?  Thank you.
  • Schulz Jordan
    Schulz Jordan over 4 years ago +1
    As you notice it says "file already in use" may be you have 2 user logins & it is open in other user login. Better restart your PC and check with issue. Or if library is saved on network make sure the…
  • Schulz Jordan
    0 Schulz Jordan over 4 years ago
    As you notice it says "file already in use" may be you have 2 user logins & it is open in other user login. Better restart your PC and check with issue. Or  if library is saved on network make sure the folder where it is saved has read-write facility & no one else is working on the library. In your case I see it is on local PC referring the screenshot.
  • CseaTec
    0 CseaTec over 2 years ago
    Well, after well over 1 year since I posted this question that no one could answer, I finally figured it out myself.
    I found that something was corrupted in my LIBARY1.OLB file.  The way I resolved it was by doing the following:
    1. In OrCAD Capture, open LIBRARY1.OLB, choose File-->Export-->Library XML...
    2. Rename the library1.xml to something new (e.g. library_mycompany.xml)
    3. Edit mycompany_library.xml with a text editor and change the line near the top from:
      <Defn name="c:\users\<myfolder>\library1.olb"/>
      to
      <Defn name="c:\users\<myfolder>\library_mycompany.olb"/>
    4. Open OrCAD Capture again and choose File-->Import-->Library XML...
    5. Save the newly created library and project thereafter and close it.
    6. The next time you open your schematic projects that used the old and problematic LIBRARY1.OLB file, add in the duplicate new library, LIBRARY_MYCOMPANY.OLB and delete LIBRARY1.OLB from the schematic project, save it and close it.
    7. Completely close OrCAD Capture
    8. Reopen OrCAD Capture for a true test of the issue.
    9. Open your Schematic project again with the new library attached and viola, no more READONLY error upon first opening!
    Hopefully this helps someone else since I've suffered with it now for almost 5 years.
  • MikeO EE
    0 MikeO EE over 2 years ago in reply to CseaTec
    Thanks for your effort in finding AND posting the solution!  I had the same problem and submitted problem reports but no one was able to solve it. Your steps above appear to have fixed the problem for me.  THANKS!
