  2. Allegro X Capture CIS
  3. Is there any way to create a template project?
  • Subscribers 51
  • Views 6867
asdfafasfaf
asdfafasfaf over 4 years ago
I saw that there is Options > Design Template that has some options you can set as defaults for new sheets.
However, is there any way to create a template project? For example, a project that includes certain libraries or other settings?
  • Schulz Jordan
    0 Schulz Jordan over 4 years ago
    You can create a project with all settings you need & save it as a draft copy. when you start a new project open draft copy & save it with new name. By default you will have a ll settings preloaded.
