  2. Allegro X Capture CIS
  3. Does a Bus Entry have any function or is it graphical only...
  • Subscribers 52
  • Views 8841
Does a Bus Entry have any function or is it graphical only?
asdfafasfaf
asdfafasfaf over 4 years ago
I'm reading through the documentation for OrCAD Capture and having trouble figuring out what the Bus Entry is used for.
It is my understanding that if you have a bus MyBus[0..5], even if you have a Bus Entry, you would still have to add Net Aliases such as MyBus3 to the net in order to connect it to the bus.
So is the Bus Entry graphical only? Is it only there to make it easier to understand the schematic and has no effect on electrical connectivity?
  • Schulz Jordan
    0 Schulz Jordan over 4 years ago
    It is my understanding that if you have a bus MyBus[0..5], even if you have a Bus Entry, you would still have to add Net Aliases such as MyBus3 to the net in order to connect it to the bus.  - Yes, Bus doesn't have predefined name & you need to define them once placed while thats not the case in Netgroup
    So is the Bus Entry graphical only? Is it only there to make it easier to understand the schematic and has no effect on electrical connectivity? - Yes, until you connect a net to bus entry there is no significance of it.
