  2. Allegro X Capture CIS
  3. Creat new layout and Associate in project not working
  • State Suggested Answer
  • Answers 2
  • Subscribers 50
  • Views 9916
Edit slide getting closed
Edit slide getting closed over 4 years ago
Hi team,
We current using 17.4 version
After netlist creation we doing Create new layout and Associate in project.
We path selected input board file and Board
when click OK not moving to allegro its getting hang status. if again click
  • rg13
    0 rg13 over 4 years ago
    Could you try with input board file and Board file path without any spaces and special characters. Try to keep it simple as C:\test  OR  E:\test
    something like that.
    Give it a try and lets see how it goes.
  • Schulz Jordan
    0 Schulz Jordan over 4 years ago in reply to rg13
    There are lot of illegal characters in the path where you are exporting the files. Remove white spaces, brackets, dot & all. Only underscore is supported
  • Edit slide getting closed
    0 Edit slide getting closed over 4 years ago in reply to rg13
    Thanks much for replying.
    After change again same. any other suggestions?
  • Schulz Jordan
    0 Schulz Jordan over 4 years ago in reply to Edit slide getting closed
    As you are netlisting first time you don't have to give any board file. Leave input board file blank & netlist. Also, update to latest hotfix S032
