  2. Allegro X Capture CIS
  3. Is there any way to hide the name of a pin without disabling...
  • Subscribers 50
  • Views 8604
Is there any way to hide the name of a pin without disabling all the names?
asdfafasfaf
asdfafasfaf over 4 years ago
I'm trying to figure out how to hide the name of a pin. I found that I can disable all pin names on a part.
Is there any way to disable the pin name for just a single pin?
  • rg13
    0 rg13 over 4 years ago
    Select that pin, click RMB and choose 'Edit properties'. It opens pin properties in property editor.
    In property editor, click RMB on its name and select Display. and then choose 'Do Not Display'. It should work.
  • asdfafasfaf
    0 asdfafasfaf over 4 years ago in reply to rg13
    Thanks for your answer. I should have been more clear, I was trying to do this in the part editor so that I don't have to do that every time I place a part. Is that possible?
