  2. Allegro X Capture CIS
  3. View "browse pins present on parts" with no entries
  • Subscribers 50
  • Views 2333
eddo
eddo over 4 years ago
Hello everyone, need some help here.
I'd like to use the "browse pins present on parts" view -
to access it I select a project containing a test component having power pins and use the menu item "Edit>Browse>Power Pins"
After the pop up "Browse properties" I Invariably get a blank list.
The other browse views (Parts, Nets, etc.) are populated instead.
What am I doing wrong?
Does that view work for someone? Using Capture CIS 17.4 S031
Thanks.
  • rg13
    rg13 over 4 years ago +1
    I can see the power pins by Edit > Browse > power pins. Can you try it on sample design bench_allegro.dsn and see whether it works for you or not? If it works for this design then probably, its related…
  • rg13
    0 rg13 over 4 years ago
    Can you try it on sample design bench_allegro.dsn and see whether it works for you or not? If it works for this design then probably, its related to your test component.
  • eddo
    0 eddo over 4 years ago in reply to rg13
    Thanks!!, I indeed can see that list populated too.
    I'll try to figure out why it does not work with other files...
    for instance with lowpass.dsn (in tools\capture\tclscripts\caplearningresources\hybrid\supportfiles\PSpiceAdvanceAnalysis\Sensitivity\designFiles) there is component with power pins, the list is empty too.
    I am obviously missing some basic info Dizzy face- I'll try to understand why. Arcane.
  • eddo
    rg13 would you be so kind, when you have got time, to try with the lowpass.dsn file to see if you get the list populated?
    I did not manage to find a reason yet. Might be a bug - I just wanted to check it is not something depending on my environment configuration.
    Thanks for your patience and help.
