  2. Allegro X Capture CIS
  3. OrCAD Capture DRC fails to find unconnected pin even though...
  • Subscribers 52
  • Views 3457
OrCAD Capture DRC fails to find unconnected pin even though "Check Unconnected Pins" is selected in DRC rules setup
SimpleFix
SimpleFix over 4 years ago
There is a capacitor pin in my schematic that is not connected to anything nor does it have the "No Connect" X on it (C706 in the picture). When I run DRC with the rules below, which include "Check Unconnected Pins", the DRC does not find this unconnected capacitor pin. How do I make the DRC find these unconnected pins correctly? I happened to find this one manually before sending to layout. I ensured there were no exceptions and that DRC was running on the entire design.
Capture 17.4-2019 S028 64-bit
  • Schulz Jordan
    0 Schulz Jordan over 3 years ago
    Try renaming capture.ini & try generating DRC
  • RohitRohan
    0 RohitRohan over 2 years ago in reply to Schulz Jordan
    Hai Schulz, did you get the solution? Because i am also facing the same problem.
