  2. Allegro X Capture CIS
  3. (17.4) Capture crashing when I have Capture and PCB editor...
  • Subscribers 50
  • Views 7955
(17.4) Capture crashing when I have Capture and PCB editor open at the same time.
tstone
tstone over 3 years ago
After updating a schematic I use the 'update layout' button to push my changes across to my PCB. As soon as I make a change in the PCB editor (select/move components, save the board file etc) capture crashes. I'm having to close capture every time I use PCB editor and work from a PDF schematic rather than the schematic in capture. I have just installed the latest hotfix (17.4-2019 SO34) but it has not fixed the issue. Has anyone else experienced this?
  • AyushD
    0 AyushD over 3 years ago
    Is it happening with particular design or while working with all the designs ?
  • tstone
    0 tstone over 3 years ago in reply to AyushD
    All designs as far as I can tell
  • rg13
    0 rg13 over 3 years ago in reply to tstone
    I suggest you to report this issue to Cadence customer support.
