  2. Allegro X Capture CIS
  3. error orcis-4006 export to excel failed
  • Subscribers 50
  • Views 7968
Johannes Marelli
Johannes Marelli over 3 years ago
i have a problem that if i want create a BOM, if i do not use "export BOM report to Excel it works.
Than i get that error message.
If Excel is open or not it does not change the problem.
Allegro will be closed with not more infos.
Johannes
  • Akshay khosla
    0 Akshay khosla over 3 years ago
    This issue is most probably with MS office therefore please do the installation/repairing/re-installation of the MS office and try again.
  • Johannes Marelli
    0 Johannes Marelli over 3 years ago in reply to Akshay khosla
    Hello thanks for the fast replay. Are you sure that is the reason.
    I tried first: I have repairing Office => Not work
    Than
    I deinstall all office and install office 365 again => Not work
    Now I do not know what I can do more.
    Johannes
  • Johannes Marelli
    0 Johannes Marelli over 3 years ago in reply to Johannes Marelli
    I have found the problem Delete all files in that folder
    %Temp%
