  2. Allegro X Capture CIS
  3. Capture 17.4 - Allegro properties no longer available in...
  • State Verified Answer
  • Subscribers 52
  • Views 2957
Capture 17.4 - Allegro properties no longer available in Capture property editor
jgregoire
jgregoire over 3 years ago
In the past, when I would edit properties on something (a net, for example), in the "Filter By" dropdown box I could select Allegro Designer (or some similar phrase), and it would bring up a whole bunch of PCB-related properties, such as NET_SPACING_TYPE and NET_PHYSICAL_TYPE.
At some point, all the Filter By dropdown options disappeared except for "<Current properties>," which has a woefully short set of properties. When I open up a schematic where nets definitely have the above properties, they do not show up under Current Properties, and if I netlist a PCB, they are not set in the PCB either.
I am the only one on my team with this problem.
Is there some terribly-labeled checkbox somewhere I need to toggle?
  • leo2
    leo2 over 3 years ago +1 verified
    take a copy of the prefprop.txt file from one of the people on your team and replace yours, it will fix it
  • leo2
    +1 leo2 over 3 years ago
  • jgregoire
    0 jgregoire over 3 years ago in reply to leo2
    That fixed it. Thanks!
  • leo2
    0 leo2 over 3 years ago in reply to jgregoire
    cheers
