  2. Allegro X Capture CIS
  3. Connect IC to High Pin Count Connector
  • Subscribers 51
  • Views 8261
jritter
jritter over 3 years ago
Hi all,
as a beginner in Cadence Tools i am searching for help.
I have to connect several chips (80 Pins) to several different HPC connectors ( 450 pins, ~1500total). The mapping is given. Is there any way to easily do that, e.g. with an  excel sheet or so?
Best regards
Julian
  • RFinley
    RFinley over 3 years ago +1
    I think there's a SKILL script solution. Have a method that allows you to place single pin parts on each net to drive net alias assignments at the connector to prevent/minimize via transitions... The…
  • RFinley
    0 RFinley over 3 years ago
    The process starts by adding temporary single-pin components to the schematic having the final net alias name and add temporary net aliases on the connector side.
    Ideally, these 1-pin temp parts would be a padstack small enough to cause a DRC error against one pin.  Not so large that multiple pins end up with DRC errors.  You won't be able to annotate the schematic reliably in a "first one wins" situation.
    I'm basing this on a feature of DRC error properties:   Orcad/Allegro reports net names on both offending pins for each pad-to-pad DRC violation.
    • As you plan out routing, place the temporary components close enough to connector pins having a "TEMP" net alias assigned to cause the error.  You want a pin-to-pin DRC error because that is what the script reads from.
    • Using the short Skill script in GitHub, parses each of the pad-to-pad DRC errors, checks that one or the other net alias in the DRC error has a TEMP prefix.
    • If it does, write out a line that renames the TEMP- net alias to match the final alias name.    This merges the two nets together after you upload an updated netlist. Skill code generates an annotation script to update your Orcad/Capture CIS schematic.
    • After routing and annotation is complete, remove the temporary pad components from the schematic and netlist to the board to remove the single pin components.
    I work for a CIS shop.  I wrote the framework for Concept HDL.  I don't have a library built to run HDL.  HDL annotation script generation is untested.
    community.cadence.com/.../skill-method-to-optimize-netlist-pin-assignments-during-routing-using-allegro-orcad
  • jritter
    0 jritter over 3 years ago
    Thank you, is there any option using SKILL in Allegro Design Entry CIS? When typing SKILL in Capture command window, the error: invalid command name "skill" occurs.
  • RFinley
    0 RFinley over 3 years ago in reply to jritter
    I have not found any SKILL implementation in Orcad Capture.  Only Tcl.
    I am at best a hobbyist-grade software guy.
    every time I do manual netlist assignments, its guaranteed the design engineers will make a change that rips everything up.
  • jritter
    Since Orcad does not seem to support SKILL , TCL could be an option. Is there a way to find pins of an instance and connect them in a loop with a wire to another instance pin? It is really hard to find any documentation.
  • rg13
    0 rg13 over 3 years ago in reply to jritter
    Look for OrCAD_Capture_TclTk_Extensions.pdf at <Installation_dir>\tools\capture\tclscripts\. It covers almost all commands related to Capture's TCL APIs.
