  2. Allegro X Capture CIS
  3. OrCAD 17.4 Online DRC ORCAP-2434 poping up for ALL symbols...
  • State Suggested Answer
  • Answers 1
  • Subscribers 50
  • Views 9915
sinking
sinking over 3 years ago
When I load the design, the online DRC CRCAP-2434: Footprint xxx specified in PCB Footprint for instance yyy is missing. Ensure xxx is in the library path. I searched the past posts.
The [Part Library Directories] in Capture.ini was added.
The padpath and psmpath in the PCB editor are right.
I can maunually place the footprint (Place/Components Manually/Placement List/Package symbol). All footprints were there.
The online DRC warnings still pop up every time I opened the capture.
All the .dra files are in the same directory.
Anything else I need to check? Are .psm files needed to get rid of the 2434 warning?
My OrCAD version is 17.4
  • rg13
    rg13 over 3 years ago +1 suggested
    You can refer following article for the solution of your issue which I found on Cadence online support portal: Article (20490897) Title: WARNING(ORCAP-2434): Footprint 'smdcap' specified for instance…
  • rg13
    0 rg13 over 3 years ago
    Article (20490897)
    Title: WARNING(ORCAP-2434): Footprint 'smdcap' specified for instance C* is missing. Ensure 'smdcap' is in library path.
    URL: https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O3w000009xwZEEAY&pageName=ArticleContent
    All the details related to this warning is given under this article.
