  2. Allegro X Capture CIS
  3. How do you assign reference designators to parts in the...
  • Subscribers 49
  • Views 7357
How do you assign reference designators to parts in the design?
yugandhar
yugandhar over 3 years ago
Part References are critical in a schematic design. This is how we read or navigate the entire design. Assigning correct references is critical in the design and board layout process.
The annotation feature assigns reference designators to all components or selected components while placing them on the schematic page automatically. Organizations follow different standards or patterns for reference assignment which helps in easy reading of the schematic, generating reports, simulating it, and locating the components on the physical board.
With the complexity of designs increasing day by day, which of the following method will you prefer to annotate your design?
  1. Components can be incrementally annotated as per placement from left to right or top to bottom of page.
  2. Parts are placed without part references initially and the entire design is annotated after completing it.
  3. Annotate the design with page level or block level controls.
  4. Component are assigned references based on their part reference prefix.
  5. Use custom script to assign reference as your requirement
Let us know if you use any other method for reference assignment.
Yugandhar.
  • Minet
    Minet over 3 years ago
    Our company uses a custom script. The refdes is based on a part prefix and the numbering on each page starts with sheet number x 100. Example first resistor placed on sheet 1 is R100, second resistor is R102. On sheet 20 the first resistor is R2000, second resistor R2001. When we look at the BOM we can immediately know which sheet (and thus which functionality, if we've recently worked with the schematics and remember what is on each sheet) a component belongs to.
