  2. Allegro X Capture CIS
  3. OrCAD – Tip of the Week: Change the date format in the Title...
  • Subscribers 50
  • Views 7213
OrCAD – Tip of the Week: Change the date format in the Title block
yugandhar
yugandhar over 3 years ago
OrCAD Capture lets you change the date format in the Title block as per your requirement.
  1. Select the design.
  2. Go to Options > Design Properties and select the Miscellaneous tab.
  3. In the Date Format section, click the dropdown icon to select from the various available date formats as shown in the following figure:
This change reflects in the Title block.
  • rrascher
    0 rrascher over 3 years ago
    Would be good if it would be user adjustable. E. g. according to ISO 8601 standard by entering a format string like "dd. mm. yyyy" or so.
