  2. Allegro X Capture CIS
  3. OrCAD Capture Constraint Manager PCB Flow​ v22.1QIR2 ->...
  • State Verified Answer
  • Subscribers 50
  • Views 2056
OrCAD Capture Constraint Manager PCB Flow​ v22.1QIR2 -> OUTA and OUTB missing constraint manager signals missing (beginner)
luqa
luqa over 3 years ago
i try the lab/tutorial
But if i open the constraint manager (lab module 2 page 40) i can not find the outa and outb names.
although other wires/net are missing, in properties i saw them all.
i think i am missed something.
why is outa and outb not in the constraint manager physical -> net -> all layers and only in properties?
thanks a lot
  • luqa
    luqa over 3 years ago in reply to Akshay khosla +1 verified
    Hello, i started over and the missing outs are gone. i think it was my fault, after tried the tutorial again, everything works. sorry for that. greetings
  • Akshay khosla
    0 Akshay khosla over 3 years ago
    Hi Iuqa,
    As it seems to be related to specific circuit and may need some data sharing hence you will be contacted via separate channel of communication.
  • luqa
    +1 luqa over 3 years ago in reply to Akshay khosla
    sorry for that.
    greetings
