  2. Allegro X Capture CIS
  3. Unified CIS Error ORCAP-2472 Library doesn not exisit
  • State Suggested Answer
  • Answers 1
  • Subscribers 50
  • Views 7901
devajh
devajh over 3 years ago
Every time i try to use Unified search i get this error. I have checked that library does exist at the location specified but somehow it is not able to retrieve it.
I have tried setting location as environment variable but no luck.
Can any one please help?
  • rg13
    rg13 over 3 years ago +1 suggested
    To rectify this error, check for the " PSpiceSymLibPath " value in the Capture.ini file present at the %CDS_HOME% location ( C:\cds_spb_home\cdssetup\OrCAD_Capture\17.4.0\Capture.ini ) on your system.…
  • rg13
    0 rg13 over 3 years ago
    To rectify this error, check for the "PSpiceSymLibPath" value in the Capture.ini file present at the %CDS_HOME% location (C:\cds_spb_home\cdssetup\OrCAD_Capture\17.4.0\Capture.ini) on your system.
    Make sure that one of the paths appended in "PSpiceSymLibPath" corresponds to the location of the breakout.olb folder (In your case it is D:\SOFTWARES\CadenceOrcad\tools\capture\library\pspice).
    If it is missing, add the correct path.
