  2. Allegro X Capture CIS
  3. Bug: The NetGroup Block lose main Pin
  • Subscribers 50
  • Views 4549
daivermaster
daivermaster over 3 years ago
Steps to reproduce:
1. Create simple netgroup with two wire
2. Create NetGroup Block
3. Change input/output pins to bidirectional
4. Copy/Paste NetGroup Block or modify NetGroup and NetGroup Block will lose main Pin
Allegro Design Entry CIS 22.1 S006
  • rg13
    0 rg13 over 3 years ago
    This problem occurred since the netgroup entry pin type was changed from output to bidirectional. The pin type of netgroup entry pin has special meaning. It detects a netgroup entry pin based on its pin type. A Cadence change request (CCR) is already there with development team to ease out the current restriction.
