  2. Allegro X Capture CIS
  3. Error: At least one field is required for defining the Propagation_Delay...
  • Subscribers 51
  • Views 5316
Error: At least one field is required for defining the Propagation_Delay property is missing
HIYO
HIYO over 3 years ago
Dear Team ,
When I am running the DRC on my schematic I am getting an error as shown below.
The hierarchical section of this error is shown below.
This is an interface between EMMC memory and SoM.when I checked the flat nets of emmc memory I obtained as shown below.
I think if I remove this property(PROPAGATION_DELAY) I can solve this issue.Please correct me if I am wrong.
May I know how to remove this error.
Regards
HARI
  • AyushD
    AyushD over 3 years ago +1
    Make sure that you use the correct syntax for specifying a value for the PROPAGATION_DELAY property. The syntax is: <Pin_pair>:<min_value>:<max_value>
  • AyushD
    0 AyushD over 3 years ago
  • Schulz Jordan
    0 Schulz Jordan over 3 years ago
    You need to define the propagation delay rules in constraint manager not as a individual component property
