  2. Allegro X Capture CIS
  3. Is there a way in Capture to highlight selected nets?
  • State Suggested Answer
  • Answers 1
  • Subscribers 51
  • Views 11187
mbmsv
mbmsv over 3 years ago
Is there a way to highlight the nets I have selected with a mouse (not through the search) in the whole design?
Thanks.
  • AyushD
    AyushD over 3 years ago +1
    If you want to highlight a particular net in the page, select that net, right click and select "select entire net", this will highlight that net on your design page. If you want to track that net in…
  • mbmsv
    mbmsv over 3 years ago in reply to AyushD +1
    I am looking for a way to highlight selected nets in the whole design persistently. Signals is OK but it doesn't work for a group of randomly selected nets. It appears that what I want is not possible…
  • mbmsv
    mbmsv over 3 years ago in reply to steve +1
    Unfortunately, this method is too slow. In my opinion, the "highlight net" has to be accessible directly from the menu that opens on the mouse right-click just like in e.g. old P-CAD 2006. It would also…
  • AyushD
    0 AyushD over 3 years ago
    If you want to track that net in your whole design, you can select the net, right click and select "Signals", this will open the signals window and you can navigate to that net by double clicking on the signals and it will take you to that corresponding page and highlight that particular net.
    Is this what you are looking for ?
  • mbmsv
    0 mbmsv over 3 years ago in reply to AyushD
    I am looking for a way to highlight selected nets in the whole design persistently. Signals is OK but it doesn't work for a group of randomly selected nets. It appears that what I want is not possible in Capture. How difficult it would be to write a custom add-on of some sort that would do it?
  • steve
    0 steve over 3 years ago in reply to mbmsv
    There is also the option to change the net properties which may give you what you need. Not quite highlight but a similar affect. Select the wire then right click - Edit net properties and choose a color, line style / thickness. Once you click OK this applies to the entire net across the design.
  • mbmsv
    0 mbmsv over 3 years ago in reply to steve
    Unfortunately, this method is too slow. In my opinion, the "highlight net" has to be accessible directly from the menu that opens on the mouse right-click just like in e.g. old P-CAD 2006. It would also be nice to be able to open a list of all nets in the design and to be able to manipulate the net names and other properties from it, again as in the old P-CAD 2006, although I suspect there are even better and more powerful examples.
  • steve
    You can use Edit - Browse - Nets to adjust properties on nets in a worksheet but you won't be able to edit the netname itself, for that try Edit - Global Replace. I would also say that there is a post in the forum OrCAD Capture CIS productivity Improvement - Capture CIS - PCB Design - Cadence Community where you can ask for enhancements so make your suggestion there.
