  2. Allegro X Capture CIS
  3. Trouble Simulating a High-Frequency Circuit in OrCAD Ca...
  • Subscribers 51
  • Views 5380
Trouble Simulating a High-Frequency Circuit in OrCAD Capture
Ruby Grace
Ruby Grace over 3 years ago
I'm working on a project that involves a high-frequency RF circuit. I've designed the circuit diagram using OrCAD Capture and set up the simulation environment accordingly. However, when I run the simulation, I'm not getting the results I expected. The circuit seems to be behaving differently than anticipated, and I'm having trouble pinpointing the issue.
I've double-checked the components and connections in the circuit diagram, and everything looks accurate to me. I'm using appropriate models for RF components and have considered the parasitic elements as well. I suspect it might have something to do with the simulation settings or perhaps some intricacies related to high-frequency simulations that I might not be aware of.
  • AyushD
    0 AyushD over 3 years ago
    Can you share what exactly is the issue you are facing ?
    If you can share some snapshots or more details about the problem, we can try to see what might be causing the issue.
  • RFinley
    0 RFinley over 3 years ago
    Without parasitic extraction of component packaging and the pcb, not sure you can get useful results for RF with "ideal" connections in p-spice.
    RF Engineers use MW/HFSS for circuit blocks.
    Much of the design comes from adding stuffing options and alternate paths to the pcb to finish the design on the bench.
