  2. Allegro X Capture CIS
  3. Creating a symbol with 5000+pins & 24 sections (OrCAD Capture...
  • State Verified Answer
  • Subscribers 50
  • Views 3408
Creating a symbol with 5000+pins & 24 sections (OrCAD Capture 17.2 CIS)
khuang128
khuang128 over 3 years ago
Hi all (OrCAD Capture 17.2 CIS),
I'm trying to create a symbol with 24 sections and 5000+ pins.   I organized a spreadsheet and tried to load it into the symbol generator but it looks to cap at 4096 pins.
Is it possible to generate a symbol with such a large pin count?
K
  • CadAP
    CadAP over 3 years ago +1 verified
    HI Khuang, Did you try Add Pins in the Spreadsheets GUI. You can click on Add Pins and give number form 1-1000. You can repeat the steps to add more pins by same procedure. Hope this helps…
  • CadAP
    +1 CadAP over 3 years ago
    HI Khuang,
    Hope this helps!
  • khuang128
    0 khuang128 over 3 years ago in reply to CadAP
    Thank you so much!  That solution worked perfectly.  -K
