  2. Allegro X Capture CIS
  3. Connection of offpage with GND symbol
  • State Suggested Answer
  • Answers 1
  • Subscribers 50
  • Views 5296
tanvi12
tanvi12 over 3 years ago
As seen in the below image, I have added one offpage conection to GND which means that I have shorted GND with this offpage connection.
But in our design, this two nets are separated. One has become GND and other 24V_IO_3.
Can anyone answer why this two nets are not shorted in entire design.
  • Akshay khosla
    Akshay khosla over 3 years ago +1 suggested
    Hi, When we connect ground symbol with an offpage connector, ground symbol becomes local to that schematic folder and will not be able to transfer the GND signal to another schematic folder as it is…
  • Akshay khosla
    0 Akshay khosla over 3 years ago
    When we connect ground symbol with an offpage connector, ground symbol becomes local to that schematic folder and will not be able to transfer the GND signal to another schematic folder as it is no longer global symbol now hence you are seeing this behavior.
