  2. Allegro X Capture CIS
  3. Creating custom refdes
  • State Verified Answer
  • Subscribers 51
  • Views 5660
Sky Panda
Sky Panda over 3 years ago
I'm trying to create custom refdes on the OrCAD schematic. I've reset the part references all to ? but I don't understand how to create a range of numbers I can use for example, I want one sheet to have ref des range of 100-199 and another sheet to only have refdes range of 200-299 but I'm not sure how to do this. Please could you help me?
  • Akshay khosla
    Akshay khosla over 3 years ago +1 verified
    Hi, You can achieve this from the annotation window which can be opened using Tools menu> Annotation. Select Refdes control option as shown below In right side, you can do the annotation page wise…
  • Akshay khosla
    +1 Akshay khosla over 3 years ago
    In right side, you can do the annotation page wise by providing the ranges.
    Akshay
  • Sky Panda
    0 Sky Panda over 3 years ago in reply to Akshay khosla
    Thank you so much Akshay!
  • kevinlin
    0 kevinlin over 2 years ago in reply to Akshay khosla
    One follow-up question regarding refdes control required option: what if I have a 3-section heterogenous part which is located on different pages? when I annotated the design based on your suggestion, the section 1 on page1 is U100A for example and section 2 on page2 becomes U200B, which is obviously wrong. What is the correct way of annotating such heterogenous part?
