  2. Allegro X Capture CIS
  3. OrCAD PDF Export Garbled Code
  • State Suggested Answer
  • Replies 7
  • Answers 1
  • Subscribers 52
  • Views 9927
SimonLym
SimonLym over 3 years ago
Hey Guys,
When using OrCAD PDF Export with both Acrobat Distiller and Ghostscript 64-bit (with default convert argument), I can successfully generate PDF files.
However, when I select any character (e.g., Text, Reference, Value, or Alias) and copy them, I receive garbled code. (e.g., copy 'R47' get '!')
Additionally, I am unable to search for specific parts by reference in the PDF (e.g., searching for "R47" yields no results).
Can someone tell me how to fix it?
Hope to receive a response.
Best regard.
  • rg13
    rg13 over 3 years ago +1 suggested
    Which hotfix of the tool you are using? Go to main menu Help > About and check. Also, you are copying R47 from smart PDF and where are you pasting it? Are you facing this issue on all of your designs…
  • FormerMember
    0 FormerMember over 2 years ago
    It creates "CapPropMark.ps, CapOutput.ps and  CapMark.ps" but failed to create .pdf. Can you help?
  • Ulf K
    0 Ulf K over 2 years ago in reply to FormerMember
    Selecting PDF Export without having highlighted the schematic (page) in the hierarchy tree results in those two (empty) .PS files.
