  2. Allegro X Capture CIS
  3. OrCAD PDF Export Garbled Code
  • State Suggested Answer
  • Replies 7
  • Answers 1
  • Subscribers 52
  • Views 9921
SimonLym
SimonLym over 3 years ago
Hey Guys,
When using OrCAD PDF Export with both Acrobat Distiller and Ghostscript 64-bit (with default convert argument), I can successfully generate PDF files.
However, when I select any character (e.g., Text, Reference, Value, or Alias) and copy them, I receive garbled code. (e.g., copy 'R47' get '!')
Additionally, I am unable to search for specific parts by reference in the PDF (e.g., searching for "R47" yields no results).
Can someone tell me how to fix it?
Hope to receive a response.
Best regard.
  • rg13
    rg13 over 3 years ago +1 suggested
    Which hotfix of the tool you are using? Go to main menu Help > About and check. Also, you are copying R47 from smart PDF and where are you pasting it? Are you facing this issue on all of your designs…
  • SimonLym
    0 SimonLym over 3 years ago
    Copy and paste "R47" will get "!". in UTF-8, is \x21\xF4808080\x17
  • rg13
    0 rg13 over 3 years ago
    Are you facing this issue on all of your designs or Is it design specific?
    I testes it at my end on 17.4 S038 and not facing this issue. I copied reference and text present on PDF and pasted it on schematic in Capture without any issue. OS used is windows 10 - 64 bit. System language is English.
  • SimonLym
    0 SimonLym over 3 years ago in reply to rg13
    Thanks for your tips. My Windows 11 system language was Chinese, but I have changed it to English. Now, I have excellent Smart PDF output. Thanks!
  • SimonLym
    0 SimonLym over 3 years ago in reply to SimonLym
    Can anyone tell me why? Windows encode problem?
  • ggeorgg
    0 ggeorgg over 2 years ago in reply to SimonLym
    I also experienced this issue. Default text type is "Univers" in our schematics. When I change the type to "Arial", I can search and find the text in the smart PDFs. This may be related to the fact, that Univers is a TrueType font and in the directory "C:\Windows\Fonts" there is a column where "Limited License" is displayed for Univers.
    If I use a Postscript Driver from another company (not OrCADPS_22.1), I do not have issues with the font Univers. But actually, I do not know why this driver is working differently...
