  2. Allegro X Capture CIS
  3. White screen on PCB layout.
  • State Suggested Answer
  • Answers 1
  • Subscribers 51
  • Views 5559
layoutguy
layoutguy over 3 years ago
Using 17.2 (SPac 88) and when i remote into my computer from home i see a white screen instead of the pcb. The board is there just not visible. Any help would be greatly appreciated! -DC
  • ICDesignAddiction
    0 ICDesignAddiction over 3 years ago
    Greetings,
    Head to the display tab and go to colors, there you can edit the color of the background, if it didn't work for you just enable the command in the view menu and type "color192", then you can go to display tab and change background color, or use "GFX_SetBackgroundColor(Black)"
    I hope my answer fixes your problem.
  • layoutguy
    0 layoutguy over 3 years ago in reply to ICDesignAddiction
    Actually it appears that I needed to disable Open GL in User Preferences-Display. Microsoft Windows Remote Desktop does not allow GPU rendering by default.
