  2. Allegro X Capture CIS
  3. Orcad Capture: Keep the references and delete the under...
  • State Suggested Answer
  • Answers 1
  • Subscribers 52
  • Views 8634
Orcad Capture: Keep the references and delete the underlined
calinixta
calinixta over 2 years ago
I got a new design with all references underlined.
If i can reset the references, to ? it deletes the unrderlined but i lose the old references.
How can i keep the references and delete the underlined?
  • steve
    0 steve over 2 years ago
    These are User Assigned References (so either edited manually or via a back annotation from the PCB). You can select each one and right click - User Assigned Reference - Unset. But if you don't care about it being user assigned go to Options - Extended Preferences - Schematic and uncheck the setting for Display "_" on user assigned part references and that should remove them.
  • bengelJF
    0 bengelJF over 2 years ago in reply to steve
    Worth noting as well that some operations in Capture will allow you to filter out user assigned references, so that automated processes (e.g., renumbering in a schematic) don't change reference designators you may have set up in a specific way.
    User assigned references also don't show up in a PDF export of the schematic, so you can still use this functionality without it impacting the readability of the schematic for other users.
  • calinixta
    0 calinixta over 2 years ago in reply to steve
    Thank you for the help
