  2. Allegro X Capture CIS
  3. PASS (schema) Net Custom Property from Schematic to PCB...
  • State Verified Answer
  • Subscribers 50
  • Views 5337
PASS (schema) Net Custom Property from Schematic to PCB Editor
grax
grax over 2 years ago
Hi
refer to picture
I want to:
1- create a CUSTOM Net property (MyProperty) on a Net of the schematic and then
2- get that property in PCB EDITOR (Allegro Constraint Manager-worksheet = PROPERTIES > Net > General Properties) see picture
Today it is possible to do this only for the property VOLT but this field doesn't not accept STRING, only numbers unfortunately
pls help on this
Best
  • rg13
    rg13 over 2 years ago +1 verified
    I tried it at my end. It takes string along with numeral as unit 'Volt'. See below: Moreover, if you want to take any user defined net property from Schematic to layout (Capture-Allegro), then try…
  • rg13
    +1 rg13 over 2 years ago
    Moreover, if you want to take any user defined net property from Schematic to layout (Capture-Allegro), then try defining that property in Allegro.cfg under [netprops] section.
    Also, under Design Sync setup, say 'Yes' for 'Create user-defined properties' and see if it takes it in the netlist pstxnet.dat or not.
    For more details on this, you can also refer following link of article from Cadence online support portal:
    Article (20508175) Title: How to create and transfer user-defined property to PCB Editor board from Capture CIS schematic in SPB 17.4 and 22.1
    URL: support.cadence.com/.../ArticleAttachmentPortal
  • grax
    0 grax over 2 years ago in reply to rg13
    THANKs!
    this is very usefull as it allows to create NET_CLASSES properties (hispeed, powerlanes, diffpair, clock_tree, lowspeed) on Nets directly from schematic and then such properties into Nets under Allegro, where they can be further associated with DesignRules
    Actually Altium does this quite well and I was expecting OrcadX beeing capable to support such feature too; hopefully CADENCE will add this in coming releases
    bye
