  2. Allegro X Capture CIS
  3. I messed up the settings
  • Subscribers 51
  • Views 4179
Telemax
Telemax over 2 years ago
Hello. A friend lent me a laptop to look at and test OrCad and Pspice because my Multisim is too slow.
I was slowly looking through the options and possibilities, creating simple designs, and I messed something up and instead of tensions, I got something like this after running the simulation. How to fix? Because I don't really know what I'm doing.
Please help.
  • rg13
    rg13 over 2 years ago
    Are there any errors/warnings which you are getting after running simulation? You can see it in PSpice probe window where it shows the result once simulation is completed.
    Above image shows that bias point display is enabled at your end. Hence, it shows bias points for you. Markers in blue and green shows that it has shown the result in PSpice probe window as follows:
  • digital1
    digital1 over 2 years ago
    The input voltage at D2 cathode and D4 anode is very low it looks like you cut some of this circuit of to get it in the picture can you show a screen scrape of the whole circuit
    otherwise we can only guess at what is wrong.
