  2. Allegro X Capture CIS
  3. How to keep the package symbol's pins in order after back...
  • State Verified Answer
  • Subscribers 50
  • Views 2662
How to keep the package symbol's pins in order after back-annotation?
LiQY20
LiQY20 over 2 years ago
I'm now trying to design a PCB with a FMC socket, and I want to use 'swap pins' to better organize the pinouts.
However, when I swapped two pins in Allegro and back-annotated it into Capture CIS, I found that the symol package did change, but seemed wierd.
Just as this picture shows, I swapped SIG_K1 and SIG_K2, and these two pins did change. But the package's K7 and K8 pins exchanged, and that seemed wierd. This makes the package symbol looks really out of order.
Is there a way that after back-annotation it is the pin-connected circuit to be exchanged?
My suite version is SPB17.4.
  • rg13
    rg13 over 2 years ago in reply to LiQY20 +1 verified
    As I mentioned, this behavior is there to avoid connectivity conflicts. It swaps/changes the pins and keep rest of the things as it is. I have swapped B0 with B7 here in test circuit. You can see below…
  • rg13
    0 rg13 over 2 years ago
    In order to avoid any connectivity conflict at schematic front, it will show swapping in this format only.
  • LiQY20
    0 LiQY20 over 2 years ago in reply to rg13
    so you mean there's no better solution?
  • rg13
    +1 rg13 over 2 years ago in reply to LiQY20
    I have swapped B0 with B7 here in test circuit. You can see below:
    After I swap B0 with B7 in Allegro and then backannotate changes to schematic, it shows it as follows:
    Hope it helps!
