  2. Allegro X Capture CIS
  3. Generating Live BOM in OrCAD X Capture CIS
  • Subscribers 51
  • Views 6699
DesignTech
DesignTech over 2 years ago
Bill of Materials (BOM) refers to a report that lists the components present in the design. Live BOM is a dynamic BOM that is generated using supply chain data from SourceEngine. Live BOM represents an always up-to-date view of the design BOM with zero configuration.
You can access this from Tools > Live BOM.
Hope you find this feature interesting to use.
Team Design Tech
Cadence Design System
For individuals, small businesses, or teams, START YOUR FREE TRIAL.
  • digital1
    digital1 over 2 years ago
    I have gone to Tools menu however Live Bom is greyed out
    I have orcad 23.1 S001 in which I use CIP and cis is live bom compatible with CIS and cip or do i have to host my files in the cloud
  • steve
    steve over 2 years ago in reply to digital1
    The design (filename.dsn) MUST be in the workspace for LiveBOM to be active. Copy the dsn file to %HOME%\cdssetup\workspace\projects\projectname folder, then open in OrCAD X Capture and save the design then you can run LiveBOM. If you want CIP data to be used you need to modify your filename.dbc file and change the mapping for all the tables you use. Change Manufacturer to Manufacturer Name and Manufacturer PN to Manufacturer Part Number. These will then be used by LiveBOM.
  • digital1
    digital1 over 2 years ago in reply to steve
    Thanks Steve that was spot on now I can see the LiveBOM and thanks to your advice I have the relevant data for my parts
