  2. Allegro X Capture CIS
  3. How to determine in which software version footprint was...
  • State Verified Answer
  • Subscribers 50
  • Views 5027
How to determine in which software version footprint was created?
piorog
piorog over 2 years ago
I have a thousands of footprints made in various Allegro versions. With the new Allegro 23.1 I am unable to open footprints made in Allegro 16.6 and olders, as well as old padstack in the Padstack Editor 2023. I know that the old libraries can be upgraded with the DBDoctor, but is there any way to upgrade only these files that really need it? Or is there any other option to export the software version information from the .dra file?
  • SandeepVarrier
    SandeepVarrier over 2 years ago +1 verified
    You can invoke dbdoctor outside Allegro from the start menu and then browse to the folder where you have the files and then in the end of the path you can give wild character * EG: C:\Users\padstack\*…
  • piorog
    piorog over 2 years ago in reply to SandeepVarrier +1
    Thank you very much! Seems like dbstat command is what I was looking for
  • SandeepVarrier
    +1 SandeepVarrier over 2 years ago
    You can invoke dbdoctor outside Allegro from the start menu and then browse to the folder where you have the files and then in the end of the path you can give wild character * EG: C:\Users\padstack\*.pad or C:\Users\library\*.dra this cna be done to upgrade the files.
    to know the version of a  file in the command prompt use dbstat *.dra
  • piorog
    0 piorog over 2 years ago in reply to SandeepVarrier
    Thank you very much! Seems like dbstat command is what I was looking for Slight smile
