  2. Allegro X Capture CIS
  3. OrCAD Capture Constraint Manager: How can I populate all...
  • State Suggested Answer
  • Answers 1
  • Subscribers 50
  • Views 5137
OrCAD Capture Constraint Manager: How can I populate all Constraint Worksheets when importing a .csv file
EJoyce
EJoyce over 2 years ago
I am currently attempting to create template files to utilize in the constraint manager of OrCAD Capture. I have learned that I can export a single worksheet and I will be provided a .csv file that is the correct format for importing constraints.
My issue is that I am looking for a way to import multiple worksheets so that I can automatically populate many different worksheets across Electrical, Physical & Spacing Constraints with a single import.
I have attempted creating multiple sheets within a .csv file however the only sheet that is imported is the last one open when I saved it. I am also unable to select multiple .csv files while importing, it appears you can only select one at a time.
So I ask, is there a way to make this import of .csv files more efficiant so that I can populate constraints across multiple worksheets with a single import?
Regards
  • AyushD
    AyushD over 2 years ago +1 suggested
    Did you try exporting and importing the constraints via technology file (.tcfx). It will allow you to export all the constraints at once and you can import the same into CM.
  • AyushD
    0 AyushD over 2 years ago
