  2. Allegro X Capture CIS
  3. Orcad libraries font issues
  • State Suggested Answer
  • Answers 1
  • Subscribers 51
  • Views 5196
Edit slide getting closed
Edit slide getting closed over 2 years ago
We creating Libraries. If that libraries placed in schematics outline and font changes please check below image and give solution.
Lib creation
After schematics placed
  • Eric Jordan
    Eric Jordan over 2 years ago +1 suggested
    Thos has been going on since version 16.6. The problem is the font, font size and font colors in the library are set to "default". This means that the settings get updated based on the user's preferences…
  • Eric Jordan
    0 Eric Jordan over 2 years ago
    The problem is the font, font size and font colors in the library are set to "default". This means that the settings get updated based on the user's preferences when designing the schematic.
    To keep the fonts consistent, you need to override the defaults to a specific font and font size.
    You do not want to change the color though as the three themes offered inside Capture are very different and you want Capture to update colors from the theme values.
  • Ulf K
    0 Ulf K over 2 years ago
    A bit OT but in some cases, if  the characters "0" and "O" gets mixed up, then take a look at the font "Andale Mono" or "Andale Dot". I beleive these are free to use. There the characters differs from one another very clearly.
