  2. Allegro X Capture CIS
  3. allegro design entry cis 17.4 - export pdf issue
  • Replies 10
  • Subscribers 53
  • Views 7675
Rupesh M
Rupesh M over 2 years ago
Facing issue with pdf export.
Using Allegro design entry cis 17.4 and latest hotfix is installed "SPB17.40.039". still issue persist, please assist on same.
tried below options,
1. Installed latest ghostscript GPL version
2. Removed sapce in project name and tried
3. Opened old schematic to nullify design issue
4. Re-intsalled adobe pdf reader.
all three cases pdf export fails,
 Tool able to generate .ps files but no pdf
Rupesh M
  • kyle02
    0 kyle02 over 2 years ago in reply to kyle02
    The issue has reappeared.  I was able to export PDFs after reinstalling, but now it stopped working again.
  • RohitRohan
    0 RohitRohan over 2 years ago in reply to Rupesh M
    Try selecting the .dsn in the capture and try exporting the PDF, also its better to export the PDF to local drives instead of desktop location.
  • Rupesh M
    0 Rupesh M over 2 years ago in reply to kyle02
    Hello kyle02,
    The working solution is,
    1. Uninstall the complete setup,
    2. delete cadence all registry key from "registry editor"
    3. restart the system
    4.install the only base setup for allegro17.4, dont install any hotfix, it will work.
  • kyle02
    0 kyle02 over 2 years ago in reply to Rupesh M
    I can confirm that Hotfix 28 works when exporting PDF.  I didn't have the issue until Hotfix 38 and 39.
  • Ulf K
    0 Ulf K over 2 years ago in reply to kyle02
    There are "weird" things going on also with 23.1  Capture
    The schematic PDF export gets confused if selecting paper print out using a local printer. For some strange reason, wanting a preview results in a completely black screen.the second time a print attempt is made.
    Without being able to see anything though, the print out is correct. But switching between .PDF export (OrCADPS... driver) and paper print confuses the output management system.
    Sometimes it seems that color vs b/w gets confused. If having several versions like 17.2, 17.4, 22.1 and 23.1, a number of "OrCADPS..." drivers exist in the system. If removing them, they will have to be recreated by defining the output from MSPublisher and using that driver.
    I know that the driver should be configured in Windows for either B/W or color but somewhere (at least in my computer) settings have been intemixed. As I have to have all these versions installed because of downreving, the situation is sometimes "a bit" frustrating.
    Maybe Cadence should try to create a unified (print/PDF) output management system of their own. I once tried to disect the ghostscript process if any settings in that software was the cause but found nothing...
