  2. Allegro X Capture CIS
  3. Error Modifying Part Downloaded from Unified CIS
  • State Suggested Answer
  • Answers 1
  • Subscribers 50
  • Views 5746
tuck2023
tuck2023 over 2 years ago
I found a connector on the unified CIS and placed it in my schematic. Then I clicked "edit part" and changed the symbol. Unfortunately, whenever I save or try to close that tab, the symbol doesn't save and I get a bunch of error messages in the session log (pasted below). It seems the tool cannot find the path of the symbol file that was downloaded from the cloud, however I looked in my file explorer and it is in fact there (the exact path it's looking for). Perhaps it's a permissions issue?
I'm running the free trial of OrCad Capture 22.1 on Windows 10.
Here is the error log I get:
Could not find C:\Users\SSHERS~1\AppData\Local\Temp\CDN_SYMEDITOR_temp.olb
Could not find C:\USERS\SSHERS~1\APPDATA\LOCAL\TEMP\CDN_SYMEDITOR_TEMP.OLB
INFO(ORDBDLL-1229): XMATIC : Creating Library..C:\USERS\SSHERS~1\APPDATA\LOCAL\TEMP\CDN_SYMEDITOR_TEMP.OLB
INFO(ORDBDLL-1229): XMATIC : Saving Library..C:\USERS\SSHERS~1\APPDATA\LOCAL\TEMP\CDN_SYMEDITOR_TEMP.OLB
::OrHandlerSymbolEditorConfig::HandleSymbolEditorClose, C:\USERS\SSHERSHER\DOCUMENTS\FE1736_FULL_ADVLB_REV0_ORCAD\FERRIC FE1736_FULL_ADVLB_REV0_08_10_2023\FERRIC
Sam
  • rg13
    rg13 over 2 years ago in reply to tuck2023 +1 suggested
    Hey tuck, you can select respective part entry under design cache and then Design > Update cache option would be enabled for you. Or you can directly click right mouse button on part entry under design…
  • tuck2023
    0 tuck2023 over 2 years ago
    I tried making a new component symbol, copying and pasting the symbol drawing from the downloaded part, and adding it to an existing library. Now when I try to place the part I get this error:
    The option Design --> Update Cache is greyed out for me at all times, whether the part is selected or not.
  • rg13
    0 rg13 over 2 years ago in reply to tuck2023
    Hey tuck, you can select respective part entry under design cache and then Design > Update cache option would be enabled for you. Or you can directly click right mouse button on part entry under design for which you are getting this error as shown below:
    Once cache for the concerned part is updated, you won't get this error anymore.
