  2. Allegro X Capture CIS
  3. DRC error not showing for the unconnected pins
  • State Verified Answer
  • Subscribers 51
  • Views 5034
RohitRohan
RohitRohan over 2 years ago
I have problem in the schematic design, there are some components in the Capture schematic with unconnected pins but the unconnected pin error is not showing while i run the DRC errors, i have even tried renaming the capture.ini file but still the DRC not shown.
  • oldmouldy
    oldmouldy over 2 years ago +2 verified
    By default, only unconnected Input Pins and unconnected Input Ports get flagged by the check, you need to set the "action" in the ERC Matrix. Each cell in the ERC Matrix has three states: Grey - "do nothing…
  • oldmouldy
    +1 oldmouldy over 2 years ago
    By default, only unconnected Input Pins and unconnected Input Ports get flagged by the check, you need to set the "action" in the ERC Matrix. Each cell in the ERC Matrix has three states: Grey - "do nothing"; Yellow (W) - issue a warning; Red (E) - issue an error. Set all of the Unconnected cells to W, for example.
    • Vote Up +2 Vote Down
