  2. Allegro X Capture CIS
  3. ORCAD X Capture Can not Open
  • State Suggested Answer
  • Answers 1
  • Subscribers 50
  • Views 5634
AABBkkee1234
AABBkkee1234 over 2 years ago
The ORCAD viewer and capture program do not work as these screens are displayed. I have tried deleting the registry, but it does not work.
  • Akshay khosla
    Akshay khosla over 2 years ago +1 suggested
    Please check in the windows task manager if OrCAD Capture is running in background, if yes then select the capture entry and click on End Task option then try relaunching the OrCAD Capture.
  • Akshay khosla
    0 Akshay khosla over 2 years ago
  • Zhifeng Jin
    0 Zhifeng Jin 2 months ago in reply to Akshay khosla
    Hi Akshay Khosla,
    I frequently encounter this issue in OrCAD Capture 25.1. After closing OrCAD Capture, attempting to launch it again yields no response. No OrCAD Capture startup screen appears. When I open Windows Task Manager in this state, an OrCAD Capture process can be found running. I have to terminate this process before I can open the software normally. I have never experienced this problem with PCB Editor.
    Has anyone else run into this issue?
  • PatEscher
    0 PatEscher 1 month ago in reply to Zhifeng Jin
    yes, same problem here. it only happens with 25.1 and some of the later ISR's as far as I see
