  2. Allegro X Capture CIS
  3. Design SYNC net import
  • State Suggested Answer
  • Answers 1
  • Subscribers 53
  • Views 6241
Nayyier Kazi
Nayyier Kazi over 2 years ago
I am using Allegro v22.1-2022,
IN Allegro PCB editor , If R1.pin1 has net name "D0" and U1.pin1 has net name "S1" BY using NET LOGIC command we can assign "D0" of R1pin1 to U1.pin1.
now the question is can we import this change to ORCAD CAPTURE schematic by using design sync command or any other method? it is doing problem.
Thanks.
  • rg13
    rg13 over 2 years ago +3 suggested
    Basically, from schematic perspective, one net is being deleted i.e. S1 in this case. Backannotation (Update schematic) process will not do that. Any specific deletion or creation can't be done by this…
  • rg13
    0 rg13 over 2 years ago
    Basically, from schematic perspective, one net is being deleted i.e. S1 in this case. Backannotation (Update schematic) process will not do that. Any specific deletion or creation can't be done by this. It is schematic driven flow where you need to do these type of changes in schematic first and then you can take them to layout.
    Hope it addresses your concern.
    • Vote Up +3 Vote Down
  • E2202407295816
    0 E2202407295816 over 2 years ago in reply to rg13
    Thanks rg13 very much I was having this issue and using this platform it got resolved
  • KS202409118129
    0 KS202409118129 over 2 years ago
    One network, S1, is being removed in this situation. The backannotation (update schematic) technique will not do that.
    bitlife online
  • KS202409118129
    0 KS202409118129 over 2 years ago in reply to rg13
    I was having this difficulty and using this platform, it was remedied.
    bitlife online
  • KC202510281821
    0 KC202510281821 over 1 year ago
    I was a bit confused about why the net names weren’t syncing automatically. Makes sense now that it has to be done from the schematic side first.
